first image
thumb image 1
thumb image 2
Add Note Edit Step 16  ¶
  • Remove the single 28 mm T10 Torx screw securing the left speaker to the rear case.
  • Lift the left speaker up and out of the rear case. Don't try to slide the speaker out, since there is a plastic mounting pin under the top end of the speaker housing that holds it in place.
first image
Add Note Edit Step 17 — Logic Board  ¶
  • Disconnect the power button and CPU fan by lifting their connectors straight up off the logic board.
first image
Add Note Edit Step 18  ¶
  • Disconnect the SATA data cable from the logic board by carefully pulling it straight away from its socket.
  • The SATA connector on most iMacs tends to stick in its socket on the logic board. If you are having trouble disconnecting the SATA cable, insert a metal spudger or any other thin tool into the gap between the SATA connector and its socket and twist the spudger's shaft to safely separate the two pieces.
Next » « Previous
