Image #1
Add Note Edit Step 9  ¶
  • Use the attached black tab to pull the data display cable connector away from the logic board.
Image #1 Image #2
Add Note Edit Step 10  ¶
  • Remove the eight 12 mm T8 Torx screws securing the display panel to the rear case.
  • Lift the display panel from its left edge and rotate it toward the right edge of the iMac.
Image #1 Image #2
Add Note Edit Step 11  ¶
  • With the display panel still lifted, disconnect the four inverter cables.
  • During reinstallation, place the four inverter cable connectors in voids between components attached to the rear panel so the display panel will sit flush.
  • During reassembly, the order of the inverter cables is interchangeable within each socket.
  • If you are replacing a hard drive and have an extra set of hands, it is possible to reach in and remove the drive without disconnecting anything but the LCD temp and display connector in the previous step with the LCD in its propped position.
Image #1
Add Note Edit Step 12 — Optical Drive  ¶
  • If necessary, remove the pieces of tape securing the hard drive/optical drive thermal sensor cables to your iMac.
Image #1
Add Note Edit Step 13  ¶
  • Disconnect the optical drive thermal sensor connector from the logic board by pulling its connector toward the top of your iMac.
  • When removing this connector, it is helpful use your thumbnails to push the ears on either side of the connector toward the top of your iMac.
Image #1
Add Note Edit Step 14  ¶
  • Remove the two fine-thread 7 mm T10 Torx screws securing the optical drive to the rear case.
Image #1
Add Note Edit Step 15  ¶
  • Lift the free end of the optical drive slightly out of the rear case.
  • Remove the two 3.5 mm T6 Torx screws securing the optical drive connector to the optical drive.
Image #1 Image #2
Add Note Edit Step 16  ¶
  • Insert the flat end of a spudger between the optical drive connector and the body of the optical drive.
  • Twist the spudger to separate the connector from the optical drive.
  • It may be necessary to work from alternating sides of the connector until it is disconnected.
Next » « Previous
Required Tools
T8 Torx Security Bit Screwdriver
$6.95 · 50+ In stock
Spudger
$2.95 · 50+ In stock
T6 Torx Screwdriver
$4.95 · 50+ In stock
Phillips #1 Screwdriver
$4.95 · 6 In stock
T10 Torx Security Bit Screwdriver
Recommended Tools
Universal Drive Adaptor
$29.95 · 50+ In stock
iFixit Lock Pick Set
$29.95 · 31 In stock
Inspection Scope
$39.95 · 40 In stock
Frictionless Ratchet
$24.95 · 49 In stock
Portable Anti-Static Mat
$24.95 · 19 In stock
Popular Device Products
1 TB SATA Desktop Hard Drive
$129.95 · 16 In stock
Arctic Silver Thermal Paste
$8.95 · 50+ In stock
Arctic Silver ArctiClean
$7.95 · 24 In stock
