first image
thumb image 1
thumb image 2
Add Note Edit Step 10  ¶
  • Remove the eight 12 mm T8 Torx screws securing the display panel to the rear case.
  • Lift the display panel from its left edge and rotate it toward the right edge of the iMac.
first image
thumb image 1
thumb image 2
Add Note Edit Step 11  ¶
  • With the display panel still lifted, disconnect the four inverter cables.
  • During reinstallation, place the four inverter cable connectors in voids between components attached to the rear panel so the display panel will sit flush.
  • During reassembly, the order of the inverter cables is interchangeable within each socket.
Next » « Previous
For more information, check out the iMac Intel 20" EMC 2133 and 2210 device page.
Did you successfully follow this guide?
This guide has been completed 5 times.
