Installing iMac Intel 20" EMC 2133 and 2210 CPU Fan
- Author: Walter Galan
- Difficulty: Moderate
Keep your CPU running cool by replacing the CPU Fan.
Sections
- Access Door 1 step
- Glass Panel 2 steps
- Front Bezel 3 steps
- Display Panel 5 steps
- CPU Fan 5 steps
Tools
Tools (continued)
- View:
- Single page
Edit
Step 2
Glass Panel
The glass panel is fixed onto the front bezel with fourteen magnets around its perimeter.
Stick two suction cups to opposing corners of the glass panel.
To attach the suction cups we sell, first position the suction cup with the movable handle parallel to the face of the glass panel. While lightly holding the suction cup against the glass, raise the movable handle until it is parallel with the other handle.
If your suction cups refuse to stick, try cleaning both the glass panel and the suction cup with a mild solvent such as Windex.
Edit
Step 3
Gently pull the glass panel straight up off the iMac.
The glass panel has several positioning pins around its perimeter. To avoid shearing these pins off the glass panel, be sure to only pull straight up during removal.
Be meticulous about cleaning the LCD and the inside face of the glass panel before reinstallation, as any fingerprints or dust trapped inside will be annoyingly visible when the display is on.
Edit
Step 5
The front bezel is still attached to the iMac by the microphone cable.
Gently lift the front bezel from its top edge off the rear case. It helps to use your thumbs to push down very gently on the corners of the display.
Once the top edge of the front bezel has cleared the rear case, rotate the front bezel toward the stand and lift it off the rear case.
When reinstalling the front bezel, start at the lower edge and make sure it is flush with the rear case before lowering the top edge onto the iMac.
Page 1 of 2
