Installing iMac Intel 20" EMC 2105 and 2118 PRAM Battery
- Author: Walter Galan
- Difficulty: Moderate
Easily replace the coin-cell PRAM battery.
Sections
- Access Door 1 step
- Front Bezel 6 steps
- Lower EMI Shield 2 steps
- PRAM Battery 1 step
- View:
- Paginated
- Full width
Edit Step 3 ¶
Re-orient your iMac so it sits upright on the stand.
Insert a plastic card up into the corner of the air vent slot near the top of the rear case.
Push the card toward the top of the iMac to release the front bezel latch.
Pull the front bezel away from the rear case.
Repeat this process for the other side of the front bezel.
It may be necessary to apply several layers of duct tape to the top of the access card to aid in releasing the latches.
If the bezel refuses to release, try lifting the lower edge of the front bezel slightly away from the rear case (detailed in the next few steps) and repeat the latch release process.
Page 1 of 4
