first image
Add Note Edit Step 13  ¶
  • Lift the lower edge of the display and rotate it toward the top edge of your iMac.
  • Do not lift it too much, as the inverter cables are still attached.
first image
thumb image 1
thumb image 2
Add Note Edit Step 14  ¶
  • Disconnect both inverter cables from the inverter board.
  • These connectors are seated very tightly in their sockets. It is helpful to use your fingernails or the tip of a spudger to push the ears on either side of the connectors to dislodge them from their sockets. A small pair of hemostats helps a lot.
first image
Add Note Edit Step 15  ¶
  • Disconnect the two inverter cables at the top edge of the inverter using the method explained in the previous step.
Next » « Previous
