Installing iMac Intel 17" IR Board
  • Add Note x
This guide will show you how to replace the IR Board in your iMac.
Sections
Tools
first image
thumb image 1
thumb image 2
Add Note Edit Step 1 — Access Door  ¶
  • Loosen the two captive Phillips screws securing the access door to the iMac.
  • Remove the access door from the iMac.
first image
Add Note Edit Step 2 — Front Bezel  ¶
  • Remove the following four screws:
    • Three 6 mm T8 Torx.
    • One 8 mm T8 Torx.
first image
thumb image 1
thumb image 2
Add Note Edit Step 3  ¶
  • Flip your iMac over and lay it stand-side down on a flat surface.
  • To lift the front bezel off the iMac, simultaneously:
    • Use your thumbs to press in the RAM arms and hold the iMac down.
    • Use your index fingers to pull the small bridge of material on the front bezel toward yourself.
    • Pull the Front bezel up with your index fingers.
  • Once the small bridge of material has cleared the RAM arms, lift the front bezel by its lower edge just enough to clear the bottom edge of the rear case.
Next » « Previous
