Installing iMac Intel 17" Display
- Author: Walter Galan
- Difficulty: Moderate
The display must be removed to gain access to most of the internal components on your iMac.
Tools (continued)
Relevant parts
- View:
- Paginated
- Full width
Edit Step 3 ¶
Flip your iMac over and lay it stand-side down on a flat surface.
To lift the front bezel off the iMac, simultaneously:
Use your thumbs to press in the RAM arms and hold the iMac down.
Use your index fingers to pull the small bridge of material on the front bezel toward yourself.
Pull the Front bezel up with your index fingers.
Once the small bridge of material has cleared the RAM arms, lift the front bezel by its lower edge just enough to clear the bottom edge of the rear case.
Page 1 of 5
