Installing iMac G5 20" Model A1145 Optical Drive
Prerequisite Only
Prerequisite Only
This guide is only used as a prerequisite for other guides and is not a complete or useful guide when viewed independently.
  • Add Note x
first image
Add Note Edit Step 1 — Optical Drive  ¶
  • Disconnect the optical drive thermal sensor by pulling its cable toward the left edge of your iMac.
first image
Add Note Edit Step 2  ¶
  • Remove the two T6 Torx screws holding the optical drive connector to the logic board.
first image
Add Note Edit Step 3  ¶
  • Use the flat end of a spudger to pry the optical drive connector up off the logic board.
  • It is helpful to insert the spudger under the top or bottom edge of the optical drive connector and twist to separate the connector from the logic board.
Next » « Previous
