first image
thumb image 1
thumb image 2
Add Note Edit Step 4  ¶
  • Rotate the center Phillips screw on the bottom of the iMac clockwise until the rear panel clamp contacts the edge of the case.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 5  ¶
  • While depressing the connector lock, use a heavy duty spudger to pry the power supply connector away from its socket on the logic board.
  • It will be necessary to work from alternate sides until the connector is free.
  • Your power supply may have an ambient light sensor cable attached from the power supply to the logic board. If so, carefully use a spudger to push out the cable towards you using the sides of the cable alternatively to help you slide it out.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 6  ¶
  • Lift the power supply slightly from its left edge, then grab each side and rotate the power supply toward yourself.
  • The power supply requires a large amount of force to remove. You may need to bend the edge of the front case toward yourself for enough clearance to remove the power supply.
  • There are several capacitors mounted to the logic board in close proximity to the power supply. Try not to disturb them, as they are delicate and may break off the board.
Next » « Previous
For more information, check out the iMac G5 20" Model A1076 device page.
Did you successfully follow this guide?
This guide has been completed 49 times.
