Installing iMac G5 20" Model A1076 PRAM Battery
  • Add Note x
Use this guide to replace your CR2032 PRAM battery.
Sections
first image
Add Note Edit Step 1 — Rear Panel  ¶
  • Lay the iMac display-side down on a flat surface.
  • Loosen the three Phillips screws securing the rear panel to the iMac.
  • These screws are captive in the iMac. The center screw will stop turning after about 3.5 turns and the outer screws will stop turning after about 5.5 turns. Do not try to remove these screws from your iMac.
first image
thumb image 1
thumb image 2
Add Note Edit Step 2  ¶
  • Lift the rear panel slightly near the bottom of the iMac.
  • Pull the rear panel toward yourself and remove it from the iMac.
first image
Add Note Edit Step 3 — AirPort Extreme  ¶
  • Lift the AirPort card slightly by its plastic tab and pull it straight away from its socket.
  • During reinstallation, insert the AirPort card such that the antenna side is nearest the center of the logic board.
Next » « Previous
