Installing iMac G5 20" Model A1076 Midplane Assembly
  • Author: John
  • Difficulty: Difficult
  • Add Note x
Remove your midplane assembly to gain access to your display and front bezel.
Sections
first image
Add Note Edit Step 1 — Rear Panel  ¶
  • Lay the iMac display-side down on a flat surface.
  • Loosen the three Phillips screws securing the rear panel to the iMac.
  • These screws are captive in the iMac. The center screw will stop turning after about 3.5 turns and the outer screws will stop turning after about 5.5 turns. Do not try to remove these screws from your iMac.
first image
thumb image 1
thumb image 2
Add Note Edit Step 2  ¶
  • Lift the rear panel slightly near the bottom of the iMac.
  • Pull the rear panel toward yourself and remove it from the iMac.
first image
thumb image 1
thumb image 2
Add Note Edit Step 3 — RAM  ¶
  • Rotate each of the two RAM retaining arms away from the RAM chip.
  • Pull the RAM chip straight away from its socket.
  • Repeat this process for the other RAM chip.
  • Be sure the RAM arms are rotated fully outward before installing new RAM chips.
Next » « Previous
