Installing iMac G5 20" Model A1076 Bluetooth board
  • Add Note x
Regain Bluetooth functionality by replacing the Bluetooth board.
first image
Add Note Edit Step 1 — Rear Panel  ¶
  • Lay the iMac display-side down on a flat surface.
  • Loosen the three Phillips screws securing the rear panel to the iMac.
  • These screws are captive in the iMac. The center screw will stop turning after about 3.5 turns and the outer screws will stop turning after about 5.5 turns. Do not try to remove these screws from your iMac.
first image
thumb image 1
thumb image 2
Add Note Edit Step 2  ¶
  • Lift the rear panel slightly near the bottom of the iMac.
  • Pull the rear panel toward yourself and remove it from the iMac.
first image
Add Note Edit Step 3 — Bluetooth board  ¶
  • Remove the two 5.5 mm T6 Torx screws securing the Bluetooth board to the logic board.
Next » « Previous
