first image
thumb image 1
thumb image 2
Add Note Edit Step 37  ¶
  • Push the two RAM arms protruding from the access door inward and set them on the lower edge of the rear case to prevent them from getting caught when removing the logic board.
first image
thumb image 1
thumb image 2
Add Note Edit Step 38  ¶
  • Grab the logic board and pull it toward yourself slightly to separate the jacks from the rear case.
  • Rotate the top of the logic board toward yourself slightly to gain access to the DC power cable connector.
  • Do not completely remove the logic board as the DC power cable connector is still connected to the underside of the board.
first image
Add Note Edit Step 39  ¶
  • While grasping the logic board with one hand, disconnect the DC power cable connector from the logic board by pulling it straight away from its socket.
  • It may be helpful to wiggle the connector while pulling it.
Next » « Previous
For more information, check out the iMac G5 17" Model A1144 device page.
Did you successfully follow this guide?
This guide has been completed 7 times.
