Installing iMac G5 17" Model A1058 Rear Panel
  • Add Note x
  • x 8
Remove your rear panel to gain access to your iMac's internals.
first image
Add Note Edit Step 1 — Rear Panel  ¶
  • Lay the iMac display-side down on a flat surface.
  • Loosen the three Phillips screws securing the rear panel to the iMac.
  • These screws are captive in the iMac. The center screw will stop turning after about 3.5 turns and the outer screws will stop turning after about 5.5 turns. Do not try to remove these screws from your iMac.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 2  ¶
  • Lift the rear panel slightly from the bottom edge of the iMac.
  • Pull the rear panel toward yourself and remove it from the iMac.
For more information, check out the iMac G5 17" Model A1058 device page.
Did you successfully follow this guide?
This guide has been completed 8 times.
