Installing iMac G5 17" Model A1058 Inverter Replacement
- Author: Andrew Bookholt
- Difficulty: Moderate
Replace your inverter board with this guide.
Sections
- Rear Panel 2 steps
- Optical Drive 2 steps
- Inverter 5 steps
- Inverter Replacement 2 steps
Tools
Relevant parts
- View:
- Paginated
- Full width
Edit Step 1
Rear Panel
Lay the iMac display-side down on a flat surface.
Loosen the three Phillips screws securing the rear panel to the iMac.
These screws are captive in the iMac. The center screw will stop turning after about 3.5 turns and the outer screws will stop turning after about 5.5 turns. Do not try to remove these screws from your iMac.
Page 1 of 4
