Installing iMac G5 17" Model A1058 Fan Cover
  • Add Note x
  • x 3
Remove the fan cover to replace your upper fans or hard drive.
Sections
Tools
first image
Add Note Edit Step 1 — Rear Panel  ¶
  • Lay the iMac display-side down on a flat surface.
  • Loosen the three Phillips screws securing the rear panel to the iMac.
  • These screws are captive in the iMac. The center screw will stop turning after about 3.5 turns and the outer screws will stop turning after about 5.5 turns. Do not try to remove these screws from your iMac.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 2  ¶
  • Lift the rear panel slightly from the bottom edge of the iMac.
  • Pull the rear panel toward yourself and remove it from the iMac.
first image
thumb image 1
thumb image 2
Add Note Edit Step 3 — Fan Cover  ¶
  • Remove the two Phillips screws securing the fan cover to the midplane.
  • The shouldered screw belongs in the lower left corner of the fan cover.
  • Lift the fan cover up off midplane.
For more information, check out the iMac G5 17" Model A1058 device page.
Did you successfully follow this guide?
This guide has been completed 3 times.
