Installing iMac G4 17 800 MHz EMC 1936 Logic Board Assembly
Incorrect Text
Incorrect Text
This guide contains steps with ambiguous, improper, duplicate, misleading, or off-topic text.
User-Contributed Guide
This guide is not managed by iFixit staff.
Grammatical Errors
Grammatical Errors
This guide has grammatical errors or does not meet iFixit's writing guidelines.
Remove Logic Board Assembly.
  • Author: Justin
  • Difficulty: Moderate
  • Add Note x
Removing the logic board assembly to replace it with a new one.
first image
Add Note Edit Step 1 — Bottom Plate  ¶
  • Unplug all cables from the computer, including the power cable. Support the neck and base while you lay down the computer on a soft cloth.
first image
Add Note Edit Step 2  ¶
  • Loosen the four captive screws.
first image
Add Note Edit Step 3  ¶
  • Carefully remove the base access panel.
Next » « Previous
