Installing iBook G4 RAM
User-Contributed Guide
This guide is not managed by iFixit staff.
This guide will teach you how to upgrade your RAM on an iBook G4.
  • Add Note x
The RAM is what makes a computer run fast so you can multitask.
first image
Add Note Edit Step 1 — RAM  ¶
  • First you must remove the keyboard; it is very easy. There are two clips,hold both of them and pull up. Don't rip out the keyboard, just gently put it to the side.
first image
Add Note Edit Step 2  ¶
  • Unscrew the four screws you see in the center of the picture.(Ignore the one in top left.)
first image
Add Note Edit Step 3  ¶
  • Some people MAY see an AirPort card next. If you do it's very easy to remove just remove it by pulling gently.
first image
Add Note Edit Step 4  ¶
  • You should then see the RAM it should then click out. Then grab the new upgraded RAM by the edges. and stick it in the slot and push it in gently.
first image
Add Note Edit Step 5  ¶
  • Just some safety tips make sure the device is turned off, so you don't damage the device or you!
For more information, check out the iBook G4 device page.
Did you successfully follow this guide?
This guide has been completed 1 time.
