Installing iBook G4 14" 1.42 GHz Rear Display Bezel
Replace the rear display bezel in your iBook G4 14" 1.42 GHz.
- Author: Andrew Bookholt
- Difficulty: Difficult
- View:
- Paginated
- Full width
Edit Step 3
Rear Display Bezel
Use a 1.5 mm hex screwdriver to remove the two hex screws on either side of the display (four screws total).
If you don't have a 1.5 mm hex driver, you can probably get these screws out with a T6 Torx screwdriver. However, if you use a T6 Torx driver you'll be more likely to strip the screws.
Page 1 of 3
