Installing iBook G4 14" 1.42 GHz RAM
Featured Guide
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
  • Add Note x
  • x 18
One RAM slot will accept PC2700 chips up to 1 GB.
Sections
Files
Tools
Image #1 Image #2
  • Use a coin to rotate the battery locking screw 90 degrees clockwise.
  • Lift the battery out of the computer.
Image #1
Add Note Edit Step 2 — Keyboard  ¶
  • Pull the keyboard release tabs (shown in yellow) toward you and lift up on the keyboard until it pops free.
  • If the keyboard does not come free, use a small flathead screwdriver to turn the keyboard locking screw (shown in orange) 180 degrees in either direction and try again.
  • Flip the keyboard over, away from the screen, and rest it face-down on the trackpad area.
Image #1
Add Note Edit Step 3  ¶
  • Loosen the four silver Phillips screws that secure the RAM shield.
  • These screws will not come out all the way. The screws are held captive to the RAM shield to prevent them from getting lost.
Image #1
Add Note Edit Step 4  ¶
  • Remove the RAM shield from the computer.
  • The four captive screws will come out with the RAM shield.
Image #1
Add Note Edit Step 5  ¶
  • Pull the keyboard cable up from the logic board, holding the cable as close to the connector as possible.
  • When reassembling your iBook, make sure that you reconnect the keyboard cable before replacing the RAM shield.
Image #1
Add Note Edit Step 6 — RAM  ¶
  • Release the tabs on each side of the RAM chip at the same time. These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
Image #1
Add Note Edit Step 7  ¶
  • Pull the chip directly out from its socket.
Required Tools
Phillips #00 Screwdriver
$4.95 · 50+ In stock
Flathead 3/32" or 2.5 mm Screwdriver
Coin
$2.95 · 20 In stock
Related Products
PC2700 1 GB RAM Chip
$54.95 · 7 In stock
PC2700 256 MB RAM Chip
$19.95 · 10 In stock
Recommended Tools
Universal Drive Adaptor
$29.95 · 50+ In stock
iFixit Lock Pick Set
$29.95 · 17 In stock
Inspection Scope
$39.95 · 38 In stock
Frictionless Ratchet
$24.95 · 48 In stock
Portable Anti-Static Mat
$24.95 · 16 In stock
