Installing iBook G4 14" 1.42 GHz Inverter/AirPort Cables
Replace the Inverter/AirPort cables in an iBook G4 14" 1.42 GHz.
  • Add Note x
Use this guide to replace the Inverter/AirPort cables in your iBook G4 14" 1.42 GHz.
Sections
first image
  • Use a coin to rotate the battery locking screw 90 degrees clockwise.
first image
Add Note Edit Step 2  ¶
  • Lift the battery out of the computer.
first image
Add Note Edit Step 3 — Keyboard  ¶
  • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
  • If the keyboard does not come free, use a small flathead screwdriver to turn the keyboard locking screw 180 degrees in either direction and try again.
  • Flip the keyboard over, away from the screen, and rest it face-down on the trackpad area.
Next » « Previous
