Installing iBook G4 14" 1.42 GHz Fan
  • Add Note x
Replacing a defective fan is pretty easy and will keep your laptop running cool.
Sections
Files
Tools
first image
thumb image 1
thumb image 2
  • Use a coin to rotate the battery locking screw 90 degrees clockwise.
  • Lift the battery out of the computer.
first image
Add Note Edit Step 2 — Lower Case  ¶
  • Close the display and flip the computer over.
  • Remove the three hex screws using a T8 Torx screwdriver.
  • The shorter screw is in the center.
first image
Add Note Edit Step 3  ¶
  • Use a spudger or small flathead screwdriver to remove the three rubber feet from the lower case.
Next » « Previous
