View profile
Order History
Logout
Model A1134
$6.95 · 50+ in stock
$2.95 · 50+ in stock
$4.95 · 50+ in stock
$2.95 · 11 in stock
$349.95 · 6 in stock
$24.95 · 22 in stock
$7.95 · 16 in stock
$7.95 · 50+ in stock
$59.95 · 50+ in stock
$9.95 · 50+ in stock
« Previous
Next »
Page 11 of 14
Use a spudger to pry the modem up from the end nearest the AirPort card to separate its connector from a socket on the logic board.
Be sure to pry only against the heat sink or the metal framework.
Use your hands to seperate the modem from the modem shield.
Disconnect the RJ-11 cable from the end of the modem.
When replacing the modem, first make sure that both the microphone and display data cables are routed beneath where the modem lies.
Remove the three 3 mm Phillips screws securing the AirPort card bracket to the framework.
Lift the AirPort card bracket up and out of the computer.
Next » « Previous
1024
