Installing iBook G4 14" 1.42 GHz Display Inverter
Replace a blown display inverter on your 14" iBook G4 1.42 GHz.
- Author: Andrew Bookholt
- Difficulty: Difficult
Use this guide to remedy a non-lighting LCD backlight by replacing your blown-out display inverter.
Tools (continued)
Relevant parts
- View:
- Paginated
- Full width
Edit Step 2
Rear Display Bezel
Use a 1.5 mm hex screwdriver to remove the two hex screws on either side of the display (four screws total).
If you don't have a 1.5 mm hex driver, you can probably get these screws out with a T6 Torx screwdriver. However, if you use a T6 Torx driver you'll be more likely to strip the screws.
Page 1 of 7
