first image
Add Note Edit Step 46 — Logic Board  ¶
  • Remove the two Phillips screws securing the white plastic fingers of the I/O bezel to the metal framework.
  • The longer screw goes into the longer finger, closer to the display.
first image
Add Note Edit Step 47  ¶
  • Lift up the left side of the computer and slide the I/O bezel away.
first image
Add Note Edit Step 48  ¶
  • Remove the single Phillips screw securing the EMI finger to the metal framework.
  • The screw goes into the hole between the modem and ethernet ports.
  • Lift the silver EMI finger off of the metal framework.
Next » « Previous
