Installing iBook G4 12" 1.33 GHz Lower Case
  • Add Note x
Replacing the plastic bottom case.
first image
thumb image 1
thumb image 2
  • Lay your iBook upside down on a flat surface.
  • Use a coin to rotate the battery locking screw 90 degrees clockwise.
  • Lift the battery out of the computer.
first image
Add Note Edit Step 2 — Lower Case  ¶
  • Use a spudger or small flathead screwdriver to remove the three rubber feet from the lower case.
first image
Add Note Edit Step 3  ¶
  • Remove the three newly-revealed Phillips screws.
Next » « Previous
