first image
Add Note Edit Step 37 — Display  ¶
  • Remove the following three screws:
    • Two 3mm Phillips screws.
    • One 7.5 mm Phillips screw.
  • Lift the small plastic retaining bracket up and out of the computer.
first image
Add Note Edit Step 38  ¶
  • Using a spudger, pry up the AirPort/Bluetooth board from the end closest to the hard drive. Be sure to pry against the metal framework, as shown in the picture.
first image
Add Note Edit Step 39  ¶
  • Hold the AirPort/Bluetooth board in one hand and use a spudger to disconnect the two antenna cables.
  • Remove the AirPort/Bluetooth card from the computer.
Next » « Previous
