Page 1 of 1
Installing iBook G3 14" Optical Drive
- Author: iRobot
- Difficulty: Difficult
Upgrade or replace the DVD or Combo drive.
Sections
- Battery 1 step
- Keyboard 7 steps
- Lower Case 11 steps
- Upper Case 9 steps
- Bottom Shield 2 steps
- Top Shield 3 steps
- Optical Drive 8 steps
Files
- View:
- Paginated
- Full width
Edit
Step 2
Keyboard
Pull the keyboard release tabs (highlighted in red) toward you and lift up on the keyboard until it pops free.
If the keyboard does not come free, use a small flathead screwdriver to turn the keyboard locking screw 180 degrees in either direction and try again.
Flip the keyboard over, away from the screen, and rest it face-down on the trackpad area.
Edit
Step 20
Upper Case
All of the screws in the following step have small heads - the screws with larger heads hold the bottom shield on.
Remove the following 9 screws on the bottom of the computer:
Three 3 mm Phillips around the battery compartment.
Three 5 mm Phillips on the left and bottom edges.
Three 14.5 mm Phillips on the top and right edges (you may have to peel back the foil tape to reveal the screw near the security lock slot).
Edit
Step 27
The connectors at the ends of the cables are attached very firmly to the sockets on the logic board. Pulling directly on the cable will either separate the cable from its connector or the socket from the logic board.
Lift the upper case enough to disconnect the blue and white power cable from the logic board.
Using your fingernails or a dental pick, carefully pry the connector from its socket.
Make sure you are pulling only on the connector and not on the socket.
Edit
Step 32
If you have already removed the yellow tape, skip this step.
Peel back three strips of yellow tape in the bottom, left corner.
Peel back one strip of foil tape near the audio-out port, one near where the trackpad connects to the logic board, and one near where the screen latch used to be.
Edit
Step 41
Disconnect the orange ribbon cable from the optical drive.
If you have a CD or any other object jammed in your optical drive, we have an optical drive repair guide.
This guide has been completed 2 times.
Page 1 of 1
