Page 1 of 1
Installing iBook G3 14" Logic Board
- Author: iRobot
- Difficulty: Difficult
The motherboard includes all ports except the DC-In board.
Sections
- Battery 1 step
- Keyboard 7 steps
- Lower Case 11 steps
- Upper Case 9 steps
- Bottom Shield 2 steps
- Fan 1 step
- Top Shield 3 steps
- Modem 4 steps
- Hard Drive 4 steps
- IO Bezel 2 steps
- Display 8 steps
- Logic Board 8 steps
- View:
- Paginated
- Full width
Edit
Step 2
Keyboard
Pull the keyboard release tabs (highlighted in red) toward you and lift up on the keyboard until it pops free.
If the keyboard does not come free, use a small flathead screwdriver to turn the keyboard locking screw 180 degrees in either direction and try again.
Flip the keyboard over, away from the screen, and rest it face-down on the trackpad area.
Edit
Step 20
Upper Case
All of the screws in the following step have small heads - the screws with larger heads hold the bottom shield on.
Remove the following 9 screws on the bottom of the computer:
Three 3 mm Phillips around the battery compartment.
Three 5 mm Phillips on the left and bottom edges.
Three 14.5 mm Phillips on the top and right edges (you may have to peel back the foil tape to reveal the screw near the security lock slot).
Edit
Step 27
The connectors at the ends of the cables are attached very firmly to the sockets on the logic board. Pulling directly on the cable will either separate the cable from its connector or the socket from the logic board.
Lift the upper case enough to disconnect the blue and white power cable from the logic board.
Using your fingernails or a dental pick, carefully pry the connector from its socket.
Make sure you are pulling only on the connector and not on the socket.
Edit
Step 33
If you have already removed the yellow tape, skip this step.
Peel back three strips of yellow tape in the bottom, left corner.
Peel back one strip of foil tape near the audio-out port, one near where the trackpad connects to the logic board, and one near where the screen latch used to be.
Edit
Step 42
Lift the hard drive out of the computer and turn the hard drive over. Use the transparent orange loop to disconnect the hard drive ribbon cable from the hard drive.
This is a bit tricky. Try rocking the cable gently from side to side while applying even pressure. If you bend the pins, do your best to straighten them, using the hard drive cable as a guide.
Edit
Step 45
Display
If you have already removed the hard drive, ignore its presence in the following steps. The hard drive does not affect the display removal.
Disconnect the microphone cable from the front, left corner of the logic board.
Peel back the black tape and free the microphone cable from the hard drive.
Edit
Step 53
Logic Board
Remove the following 9 screws:
Two 3 mm Phillips from the edge of the logic board, near the battery
Two 4 mm large head Phillips on the port side, from either corner.
One 6 mm Phillips near the sleep light.
Two 7.5 mm Phillips securing the battery connector to the metal framework.
Two 5 mm Phillips from the logic board. These screws may not be present on some models.
There will be two screws remaining that secure the airport card cage to the logic board (can't get them all).
Edit
Step 57
Lift the heat sink out of the computer.
If you need to mount the heat sink back into the laptop, we have a thermal paste guide that makes replacing the thermal compound easy.
This guide has been completed 5 times.
Page 1 of 1
