Page 1 of 1
Installing iBook G3 14" Clutch Hinges
Replace the metal clutch hinges on your 14" iBook G3's display.
- Author: Andrew Bookholt
- Difficulty: Moderate
Use this guide to replace your display's clutch hinges.
Sections
- Battery 1 step
- Keyboard 7 steps
- Lower Case 11 steps
- Upper Case 9 steps
- Top Shield 3 steps
- Display 8 steps
- Rear Display Bezel 4 steps
- LCD Cover 5 steps
- Clutch Cover 2 steps
- Display Data Cable 4 steps
- Inverter/AirPort Cables 9 steps
- Clutch Hinges 1 step
- View:
- Paginated
- Full width
Edit
Step 2
Keyboard
Pull the keyboard release tabs (highlighted in red) toward you and lift up on the keyboard until it pops free.
If the keyboard does not come free, use a small flathead screwdriver to turn the keyboard locking screw 180 degrees in either direction and try again.
Flip the keyboard over, away from the screen, and rest it face-down on the trackpad area.
Edit
Step 20
Upper Case
All of the screws in the following step have small heads - the screws with larger heads hold the bottom shield on.
Remove the following 9 screws on the bottom of the computer:
Three 3 mm Phillips around the battery compartment.
Three 5 mm Phillips on the left and bottom edges.
Three 14.5 mm Phillips on the top and right edges (you may have to peel back the foil tape to reveal the screw near the security lock slot).
Edit
Step 27
The connectors at the ends of the cables are attached very firmly to the sockets on the logic board. Pulling directly on the cable will either separate the cable from its connector or the socket from the logic board.
Lift the upper case enough to disconnect the blue and white power cable from the logic board.
Using your fingernails or a dental pick, carefully pry the connector from its socket.
Make sure you are pulling only on the connector and not on the socket.
Edit
Step 30
If you have already removed the yellow tape, skip this step.
Peel back three strips of yellow tape in the bottom, left corner.
Peel back one strip of foil tape near the audio-out port, one near where the trackpad connects to the logic board, and one near where the screen latch used to be.
Edit
Step 32
Display
If you have already removed the hard drive, ignore its presence in the following steps. The hard drive does not affect the display removal.
Disconnect the microphone cable from the front, left corner of the logic board.
Peel back the black tape and free the microphone cable from the hard drive.
Edit
Step 40
Rear Display Bezel
Use a 1.5 mm hex screwdriver to remove the two hex screws on either side of the display (four screws total).
If you don't have a 1.5 mm hex driver, you can probably get these screws out with a T6 Torx screwdriver. However, if you use a T6 Torx driver you'll be more likely to strip the screws.
Edit
Step 63
While pulling the inverter cable away from its socket on the inverter board, use the tip of a spudger to push the connector out of its socket.
If the connector won't budge from its socket, insert a metal spudger or similar tool into the gap between the connector and its socket and twist to separate the two pieces.
This guide has been completed 0 times.
Page 1 of 1
