Installing iBook G3 14" Bottom Shield
Author:
iRobot Difficulty: Difficult
The metallic bottom shield protects the logic board from electromagnetic interference.
Embed this guide With the HTML code below, you can embed this guide as a small widget on your website.
Tools (continued) Relevant parts
Edit Step 2
Lower Case
Breathe deeply. Trying times are ahead, but we promise the lower case does come off.
Push the thin rims of the lower case surrounding the battery compartment in, bending them past the tabs, and then lift up to free that corner of the lower case.
There is a slot on the wall of the battery compartment that locks the lower case in place.
Use a small flathead screwdriver to pry out the slot's lower rim and pull up on the lower case to free the slot from the tabs holding it.
Run a spudger along the seam between the lower case and upper case on the front of the computer to free the tabs locking the lower case.
Pull up on the lower case and continue to use the spudger as necessary until you hear three distinct clicks.
Continue to run the spudger around the front, right corner.
There are two tabs on the port side of the computer, one near the front corner and one near the sound out port.
Once the front and sides of the lower case are free, turn the computer so that the back is facing you.
Pull the lower case up and toward you until the back tabs pop free.
It may be helpful to jiggle the case up and down.
Edit Step 13
Bottom Shield
For more information, check out the iBook G3 14" device page .
Fantastic! Great work!
Your profile has been updated to show that you completed Installing iBook G3 14" Bottom Shield. Change your mind? Oops, I actually didn't do it.
Did you successfully follow this guide? I did it! Success!
This guide has been completed 1 time.
