Image #1
Add Note Edit Step 9 — Lower Case  ¶
  • Your laptop should look approximately like this.
Image #1
Add Note Edit Step 10  ¶
  • Use a pin (or anything you like) to remove the three rubber feet from the lower case.
Image #1
Add Note Edit Step 11  ¶
  • Remove the three 5.2 mm newly-revealed Phillips screws.
Image #1
Add Note Edit Step 12  ¶
  • Use a spudger or small flathead screwdriver to pry up the three metal rings that housed the rubber bumpers.
Image #1
Add Note Edit Step 13  ¶
  • Remove the one 10 mm and two 20 mm hex screws using a 2mm hex. Alternatively, a T8 Torx screwdriver key will do.
Image #1
Add Note Edit Step 14  ¶
  • Remove the two 4.2 mm Phillips screws on either side of the battery contacts.
Image #1
Add Note Edit Step 15  ¶
  • Breathe deeply. Trying times are ahead, but we promise the lower case does come off.
  • Push the thin rims of the lower case surrounding the battery compartment in, bending them past the tabs, and then lift up to free that corner of the lower case.
Image #1
Add Note Edit Step 16  ¶
  • There is a slot on the wall of the battery compartment that locks the lower case in place. Use a small flathead screwdriver to pry out the slot's lower rim and pull up on the lower case to free the slot from the tabs holding it.
Next » « Previous
Required Tools
T8 Torx Security Bit Screwdriver
$6.95 · 44 In stock
Spudger
$2.95 · 50+ In stock
Phillips #00 Screwdriver
$4.95 · 50+ In stock
Flathead 3/32" or 2.5 mm Screwdriver
Coin
$2.95 · 19 In stock
Related Products
iBook G3 12" Top Shield
$14.95 · 14 In stock
Recommended Tools
Universal Drive Adapter
$29.95 · 50+ In stock
Inspection Scope
$39.95 · 17 In stock
Portable Anti-Static Mat
$24.95 · 11 In stock
