Installing iBook G3 12" Inverter/AirPort Cables
  • Add Note x
  • x 5
Use this guide to replace your inverter/AirPort cables.
Sections
Files
first image
  • Use a coin to rotate the battery locking screw 90 degrees clockwise.
  • Lift the battery out of the computer.
first image
Add Note Edit Step 2 — Keyboard  ¶
  • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
  • If the keyboard does not come free, use a small flathead screwdriver to turn the keyboard locking screw 180 degrees in either direction and try again.
  • Flip the keyboard over, away from the screen, and rest it face-down on the trackpad area.
first image
Add Note Edit Step 3  ¶
  • If the computer does not have an Airport card installed, skip the next two steps.
  • Push the wire clasp toward the Airport card and pull it up to free it from the RAM shield.
Next » « Previous
