Installing iBook G3 12" Fan
  • Author: iRobot
  • Difficulty: Difficult
  • Add Note x
  • x 3
Replacing a defective fan is pretty easy and will keep your laptop running cool.
Sections
Files
Tools
first image
  • Use a coin to rotate the battery locking screw 90 degrees clockwise.
  • Lift the battery out of the computer.
first image
Add Note Edit Step 2 — Lower Case  ¶
  • Your laptop should look approximately like this.
first image
Add Note Edit Step 3  ¶
  • Use a pin (or anything you like) to remove the three rubber feet from the lower case.
first image
Add Note Edit Step 4  ¶
  • Remove the three 5.2 mm newly-revealed Phillips screws.
first image
Add Note Edit Step 5  ¶
  • Use a spudger or small flathead screwdriver to pry up the three metal rings that housed the rubber bumpers.
first image
Add Note Edit Step 6  ¶
  • Remove the one 10 mm and two 20 mm hex screws using a 2mm hex. Alternatively, a T8 Torx screwdriver key will do.
first image
Add Note Edit Step 7  ¶
  • Remove the two 4.2 mm Phillips screws on either side of the battery contacts.
first image
Add Note Edit Step 8  ¶
  • Breathe deeply. Trying times are ahead, but we promise the lower case does come off.
  • Push the thin rims of the lower case surrounding the battery compartment in, bending them past the tabs, and then lift up to free that corner of the lower case.
first image
Add Note Edit Step 9  ¶
  • There is a slot on the wall of the battery compartment that locks the lower case in place. Use a small flathead screwdriver to pry out the slot's lower rim and pull up on the lower case to free the slot from the tabs holding it.
first image
Add Note Edit Step 10  ¶
  • Run a spudger along the seam between the lower case and upper case on the front of the computer to free the tabs locking the lower case. Pull up on the lower case and continue to use the spudger as necessary until you hear three distinct clicks.
first image
Add Note Edit Step 11  ¶
  • Continue to run the spudger around the front, right corner. There are two tabs on the port side of the computer, one near the front corner and one near the sound out port.
first image
Add Note Edit Step 12  ¶
  • Once the front and sides of the lower case are free, turn the computer so that the back is facing you and pull the lower case up and toward you until the back tabs pop free (it may be helpful to jiggle the case up and down).
first image
Add Note Edit Step 13  ¶
  • Remove the small greasy springs with white plastic caps from either side of the battery contacts.
first image
Add Note Edit Step 14 — Bottom Shield  ¶
first image
Add Note Edit Step 15  ¶
  • Remove the five 5.8 mm Phillips screws from the bottom shield.
  • Peel back the yellow tape and foil shielding outlined in the image.
first image
Add Note Edit Step 16  ¶
  • Lift the bottom shield off.
first image
Add Note Edit Step 17 — Fan  ¶
first image
Add Note Edit Step 18  ¶
  • Remove the single Phillips screw on the left side of the fan (there may be two screws).
  • Lift the fan out of its housing and disconnect it from the logic board.
For more information, check out the iBook G3 12" device page.
Did you successfully follow this guide?
This guide has been completed 3 times.
