Installing iBook G3 12" Display Inverter
  • Add Note x
  • x 5
Replace a faulty display inverter with the display attached to your iBook.
Sections
Files
first image
  • Use a coin to rotate the battery locking screw 90 degrees clockwise.
  • Lift the battery out of the computer.
first image
thumb image 1
thumb image 2
Add Note Edit Step 2 — Rear Display Bezel  ¶
  • Use a 1.5mm hex screwdriver to remove the two hex screws on either side of the display (four screws total).
  • If you don't have a 1.5mm hex driver, you can probably get these screws out with a T6 Torx screwdriver. However, if you use a T6 Torx driver you'll be more likely to strip the screws.
first image
thumb image 1
thumb image 2
Add Note Edit Step 3  ¶
  • Insert the flat end of a spudger perpendicular to the face of the display into the gap between the front and rear bezels near the upper left corner of the display.
  • Rotate the spudger away from the display to pry the rear bezel off the front bezel.
Next » « Previous
