Image #1
Add Note Edit Step 9  ¶
  • Repeat the same motions as previously mentioned to release the left side of the faceplate.
Image #1
Add Note Edit Step 10  ¶
  • Remove the faceplate from the front face of the console.
Image #1 Image #2
Add Note Edit Step 11 — Top Vent  ¶
  • Stand the console vertically with the top edge facing up.
  • The top vent is secured to the console via clips. The first two clips are located underneath the top vent closest to the faceplate, as shown in the pictures.
Image #1 Image #2
Add Note Edit Step 12  ¶
  • Insert the flat end of a spudger into the small gaps previously mentioned to release the clips.
  • You may also use the long finger of an Xbox 360 opening tool to accomplish this task.
Image #1 Image #2 Image #3
Add Note Edit Step 13  ¶
  • In the next few steps, you will use the tip of a spudger or the finger of an Xbox 360 opening tool to release the clips along the left and right sides of the top vent. Their locations are highlighted in red.
Image #1 Image #2
Add Note Edit Step 14  ¶
  • To release the clips, work from the middle of the top vent.
  • While slightly lifting the front edge of the top vent, use the tip of a spudger to push the clips closest to the center of the top vent towards the inside of the console.
Image #1
Add Note Edit Step 15  ¶
  • Use the tip of your spudger to release the clip on the top vent nearest the back of the Xbox's upper case.
Image #1 Image #2
Add Note Edit Step 16  ¶
  • The last clip is hidden underneath the rubber foot nearest the back of the console.
  • Use the tip of your spudger to release the clip on the top vent nearest the back of the Xbox.
  • Remove the top vent from the 360.
Next » « Previous
Required Tools
Arctic Silver ArctiClean
$7.95 · 50+ In stock
Related Products
Xbox 360 Red Ring of Death Fix Kit
$29.95 · 31 In stock
