Image #1 Image #2
Add Note Edit Step 33 — Cooling Fan Duct  ¶
  • Insert the flat end of a spudger into the small rectangular opening on the top of the cooling fan duct.
  • Carefully release the fan duct retaining clip and remove the fan duct from the Xbox.
  • The clip can alternatively be released using the metal finger of an Xbox 360 opening tool.
Image #1 Image #2
Add Note Edit Step 34 — Dual Fans  ¶
  • While lifting the metal chassis strip above the dual fans, pull the fans toward the center of the motherboard.
  • Do not completely remove the dual fan assembly yet. Its cable is still attached to the motherboard.
Image #1
Add Note Edit Step 35  ¶
  • Lift the dual fan connector straight up from its socket on the motherboard.
  • Some fan connectors have a locking tab. If yours has a locking tab, be sure to depress it while disconnecting the fan from the motherboard.
  • Remove the dual fan assembly from the console.
Image #1 Image #2 Image #3
Add Note Edit Step 36 — Motherboard  ¶
  • Use the flat end of a spudger to release the clips securing the RF module shield along the top and the left edge of the RF module.
  • It may be easier to use your fingernail to release the clips from the RF module.
  • Remove the RF module shield from the console.
Image #1
Add Note Edit Step 37  ¶
  • Remove three 5.6 mm T8 Torx screws securing the RF module to the metal chassis.
Image #1 Image #2
Add Note Edit Step 38  ¶
  • Grasp the RF module and lift it straight up to disconnect it from its socket on the motherboard.
  • Remove the RF module from the console.
Image #1
Add Note Edit Step 39  ¶
  • Remove the following screws securing the motherboard to the metal casing:
    • Nine gold 11 mm T10 Torx screws.
    • Eight black 5.6 mm T8 Torx screws.
  • If you are reassembling your Xbox 360 after installing the Red Ring of Death Fix Kit, the eight T8 Torx screws circled in orange are not reused.
Image #1 Image #2
Add Note Edit Step 40  ¶
  • Turn the Xbox over, being careful not to let the motherboard fall out of the chassis.
  • Lift the motherboard assembly from its front edge.
  • Be careful not to damage the sockets as you rotate the motherboard away from the metal casing.
  • Remove the motherboard assembly from the metal casing.
Next » « Previous
Required Tools
T8 Torx Security Bit Screwdriver
$6.95 · 39 In stock
Spudger
$2.95 · 50+ In stock
Flathead 3/32" or 2.5 mm Screwdriver
$4.95 · 50+ In stock
T10 Torx Security Bit Screwdriver
$6.95 · 28 In stock
Xbox 360 Opening Tool
$4.95 · 29 In stock
Related Products
