Installing TiVo Series 2 TCD540080 Motherboard
Grammatical Errors
Grammatical Errors
This guide has grammatical errors or does not meet iFixit's writing guidelines.
User-Contributed Guide
This guide is not managed by iFixit staff.
Replace a defective TiVo motherboard.
  • Add Note x
first image
Add Note Edit Step 1 — Case  ¶
  • Power down the TiVo and detach power cable from rear of unit.
    • Wait 5 minutes for unit to discharge fully before proceeding to next step.
first image
Add Note Edit Step 2  ¶
  • Remove the five T10 screws from the rear of the case.
first image
thumb image 1
thumb image 2
Add Note Edit Step 3  ¶
  • Pull the grey outer casing up and back towards yourself.
first image
Add Note Edit Step 4 — Motherboard  ¶
  • On the rear of the device, remove the right screw with a T10 Torx Screwdriver.
  • Unscrew the two black screws on the left with a T8 Torx Screwdriver.
first image
Add Note Edit Step 5  ¶
  • Disconnect the white ribbon cable from the motherboard.
    • The black base where the cable is connected is not part of the cable. Do not lift up on it!
first image
Add Note Edit Step 6  ¶
  • Remove fan power connector.
first image
Add Note Edit Step 7  ¶
  • Disconnect the hard drive data cable.
    • Use extreme caution when unplugging the connector and do not disconnect the data cable by pulling on the cable itself.
first image
Add Note Edit Step 8  ¶
  • Disconnect the connector cable that goes to the lights on the front of the device.
first image
Add Note Edit Step 9  ¶
  • Unscrew the four screws on the motherboard with a T10 screwdriver.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 10  ¶
  • Use a pair of needle-nose pliers to make the two tabs parallel with the open slots.
    • It is recommended that you do not bend these back after putting unit back together as they may break after repeated use.
first image
Add Note Edit Step 11  ¶
  • Pull the motherboard out towards the front of the TiVo unit, then pull up to remove it.
For more information, check out the TiVo Series 2 TCD540080 device page.
Did you successfully follow this guide?
This guide has been completed 1 time.
