Page 1 of 1
Installing Texas Instruments TI-92 Display
User-Contributed Guide
This guide is not managed by iFixit staff.
Inconsistent Images
This guide contains images that are inconsistent with prerequisites.
Missing Steps
This guide is incomplete or missing critical steps.
- Author: Daniel Maldonado
- Time required: 15 minutes
- Difficulty: Difficult
In this guide we will show how to remove the display to replace it if broken.
- incomplete we currently do not know how to do this and can find no information on it
Sections
- Back Cover 3 steps
- Batteries 1 step
- Back Case 6 steps
- Motherboard 1 step
- Display 5 steps
- View:
- Paginated
- Full width
Edit Step 3 ¶
"Locking Tab"
To remove the back cover, slide the cover away from the locking tab towards the bottom of the calculator until the cover no longer slides.
Then with the front of the calculator facing down, pull up on the back cover.
The calculator should now be orientated with the front facing down, as shown in picture 2.
Edit Step 4
Batteries
The Batteries are now exposed and the calculator is face down with the back towards you.
Remove the bottom batteries by pressing the battery towards you while pulling it out from the far end.
If you can not do the previous step with your finger try using a flat ended tool such as an Ipod opening tool.
After the bottom battery has been removed push or slide the other(top) battery towards you until it is fully exposed in the battery slot.
Now simply remove the battery.
Edit Step 8 ¶
Using the Ipod Opening Tool pull up on both sides of the rectangular module while keeping the rest of the calculator flat on a surface face down
You may get a lot of resistance from the module. Do not use too much force as you risk damage. Use small amounts of force to work the module out.
This guide has been completed 0 times.
Page 1 of 1
