Installing Samsung SCH-A310 Inside Screen
User-Contributed Guide
This guide is not managed by iFixit staff.
Improper Action
Improper Action
This guide contains images that improperly convey how to perform a specific action.
This guide will help anyone get to the inside screen, replace it and put the phone back together.
  • Author: Alan Blevins
  • Time required: 10 to 15 minutes
  • Difficulty: Easy
  • Add Note x
Sections
Tools
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 1 — Display Casing  ¶
  • With the phone upright and folded shut, locate the two silver tabs at the top of the screen.
  • Using one hand, pinch the two tabs inward, and use your other hand to slide the front cover of the screen off of the phone.
  • Note: Do not apply too much of force. If you find it difficult to remove the front cover, try pinching the tabs in harder, and make sure you are sliding the front cover directly downward.
first image
thumb image 1
thumb image 2
Add Note Edit Step 2  ¶
  • Using the T6 Torx screwdriver, remove each of the 4mm screws located in the corners of the phone.
  • Be sure to keep track of the little screws, since they can be lost easily.
first image
thumb image 1
thumb image 2
Add Note Edit Step 3  ¶
  • Locate the tabs on either side of the phone. Pull the outer case away from each tab with the plastic opening tool.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 4  ¶
  • Hold the phone upside-down.
  • Two plastic tabs are located under the lip of your phone. Use a plastic opening tool to pop the outer case away from the tabs.
  • After the outside case is clear of the four tabs, removed it.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 5 — Inside Screen  ¶
  • Pry the speakers from the casing, which are attached with only glue.
  • Pry the board (entire insides) from the casing using the pry tool.
  • The screen should be able to lift almost completely away as shown.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 6  ¶
  • Peel the screen from the rest of the board using your fingers. Be careful not to break anything.
  • Lastly, peel the white paper up and away from the screen to reveal the screen's electrical connection.
  • Remove the screen's electrical tab, disconnecting the entire screen from the phone.
For more information, check out the Samsung SCH-A310 device page.
Did you successfully follow this guide?
This guide has been completed 0 times.
