Image #1 Image #2 Image #3
Add Note Edit Step 9 — Camera  ¶
  • Using the plastic opening tool, you will need to detach the black square component which is boxed in blue.
  • Pry camera unit attached to it off the motherboard.
Add Note Edit Step 10 — Headphone Jack/Audio Output  ¶
  • Using the plastic opening tool, detach the green square components attaching the Audio Output device to the motherboard.
  • Now use the screwdriver to unscrew the 2 black screws holding the Audio Output device to the motherboard.
Add Note Edit Step 11  ¶
  • Now that you have unscrewed the 2 black screws, the silver plate holding the device to the motherboard should come right off.
  • Next, gently pull the Audio Output device off of the LCD touchscreen. It is secured by some weak adhesive and should come off easily.
  • You are now free to install a new Headphone Jack/Audio Output device.
Next » « Previous
Popular Products
Unibody Laptop Dual Drive
$39.95 · 50+ In stock
iPhone 4S Dock Connector
$34.95 · 50+ In stock
T8 Torx Security Bit Screwdriver
$6.95 · 50+ In stock
Probe and Pick Set
iFixit Opening Picks set of 6
$6.95 · 47 In stock
