Installing Samsung Eternity Digitizer and Screen
Incorrect Bullets
Incorrect Bullets
This guide contains bullet colors that do not match markup, or improperly-used bullet types.
User-Contributed Guide
This guide is not managed by iFixit staff.
Improper Action
Improper Action
This guide contains images that improperly convey how to perform a specific action.
To replace the digitizer and/or screen in the Samsung Eternity cell phone.
  • Add Note x
You will need to find a clean area to work in and have the necessary tools. Follow this guide to gain access to your cellphone's digitizer and screen.
Sections
No image
Add Note Edit Step 1 — Back Case  ¶
  • Remove the back battery cover.
first image
Add Note Edit Step 2  ¶
  • Remove the phone's battery.
first image
Add Note Edit Step 3  ¶
  • Remove six (4.28 x 1.25)mm screws.
first image
thumb image 1
thumb image 2
Add Note Edit Step 4  ¶
  • Use the spudger to gently pry the silver plastic back plate from the body of the phone.
first image
Add Note Edit Step 5 — Motherboard  ¶
  • It is very easy to rip motherboard cables and damage fragile motherboard clips. Be careful when you are removing every component.
  • Pull the antenna plug out of its socket.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 6  ¶
  • Pop the two black hinged-release levers toward their ribbons, then slide the ribbons out.
first image
Add Note Edit Step 7  ¶
  • Pop the red hinged-release lever away from its ribbon. Then pull it out.
first image
Add Note Edit Step 8  ¶
  • Peel the button sensor on the side of the motherboard off of the case.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 9  ¶
  • Slightly pull up one side of the motherboard.
  • Pull the button/microphone plug out of its socket.
  • Pop the red hinged-release lever away from its ribbon, then slide the ribbon out.
first image
Add Note Edit Step 10  ¶
  • You have successfully removed the motherboard from the phone.
first image
Add Note Edit Step 11 — Digitizer and Screen  ¶
  • Flip phone over so you are looking at the front screen of the phone. (The back is already taken off and parts removed)
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 12  ¶
  • Use a small tool to pry the digitizer and screen (together) from the frame of the phone. This may take some time and careful work because it is glued down to the frame.
  • Be careful when you pull the lower part of this piece away from the phone frame because there is a ribbon attached to the digitizer that you don't want to break. There is also a ribbon on the side of the screen to be aware of.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 13  ¶
  • Next, carefully pull the digitizer away from the screen.
  • At this point you can replace either the screen or the digitizer.
  • Cleaning the screen with a glass cleaning cloth before reassembling will remove any smudges or fingerprints from disassembling the device.
For more information, check out the Samsung Eternity device page.
Did you successfully follow this guide?
This guide has been completed 2 times.
