Samsung Alias 2 Camera Replacement
  1. Samsung Alias 2 Camera Replacement, Battery: step 1, image 1 of 1
    • Push down on the back cover of the phone, then remove the back cover.
  2. Samsung Alias 2 Camera Replacement: step 2, image 1 of 1
    • Remove the battery.
  3. Samsung Alias 2 Camera Replacement, Camera: step 3, image 1 of 1
    • Remove the (2) 4.1 mm screws on screen.
  4. Samsung Alias 2 Camera Replacement: step 4, image 1 of 3 Samsung Alias 2 Camera Replacement: step 4, image 2 of 3 Samsung Alias 2 Camera Replacement: step 4, image 3 of 3
    • Remove front outside casing with plastic opening tools.
  5. Samsung Alias 2 Camera Replacement: step 5, image 1 of 1
    • Use tweezers to remove the camera from its holding slot.
  6. Samsung Alias 2 Camera Replacement: step 6, image 1 of 1
    • Use a plastic opening tool to lift the tab that holds the camera ribbon in place.
  7. Samsung Alias 2 Camera Replacement: step 7, image 1 of 1
    • Use tweezers to remove the camera.
  8. Samsung Alias 2 Camera Replacement: step 8, image 1 of 1
    • Slide ribbon of new camera under the same tab.
  9. Samsung Alias 2 Camera Replacement: step 9, image 1 of 1
    • Close the tab down onto the new camera ribbon.
  10. Samsung Alias 2 Camera Replacement: step 10, image 1 of 1
    • Use tweezers to put the new camera into the camera slot that previously held the old camera.
    • WARNING: Do not touch the camera lens as it will easily scratch or smudge.
Chris
133 Reputation
5 Guides authored
Cal Poly, Team 12-35, Maness Spring 2011 Member of Cal Poly, Team 12-35, Maness Spring 2011
CPSU-MANESS-S11S12G35
4 Members
10 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 11
All Time: 2,293
