Page 1 of 1
Installing PowerBook G4 Titanium Onyx Upper Case
- Author: iRobot
- Difficulty: Difficult
Changing the top case will also give you a new trackpad, but requires removing everything from the computer.
Sections
- Keyboard 3 steps
- RAM 1 step
- Lower Case 3 steps
- Airport Card 1 step
- Hard Drive 4 steps
- DVD Drive 4 steps
- Modem 3 steps
- Logic Board 6 steps
- PC Card Cage 2 steps
- Display 11 steps
- Inverter Board 1 step
- Upper Case 1 step
Files
Tools
Relevant parts
- View:
- Paginated
- Full width
Edit
Step 13
DVD Drive
If your G4 has a CD-RW or Combo drive, the pictures in the following steps will not exactly match your computer.
Before continuing, place a soft cloth on your work surface to rest the computer on. Turn the G4 over, making sure the DVD drive doesn't fall out. Place the computer on the cloth.
Edit
Step 16
Remove the DVD drive by lifting the right edge up and out of the computer.
If you have a CD or any other object jammed in your optical drive, we have an optical drive repair guide.
Edit
Step 35
Open the display to a 90 degree angle. Rest the trackpad face down on the work surface and allow the display to hang over the edge. If possible, adjust your chair or work surface height so the display will rest on your legs and the trackpad will lie flat on the work surface.
Remove the four T8 Torx screws that fasten the display to the trackpad. The screw closest to the display data cable has a tapered head.
This guide has been completed 2 times.
Page 1 of 1
