Installing PowerBook G4 Titanium Onyx Lower Case
Author:
iRobot Difficulty: Moderate
The bottom case slides off easily after removing a few T8 Torx screws.
Embed this guide With the HTML code below, you can embed this guide as a small widget on your website.
Files Tools Relevant parts
Edit Step 1
Lower Case
Using your thumbs, slide the lower case away from you.
The lower case may stick in the front on a tab just above the center of the DVD drive. Be careful as you work the case off, or you may break the thin strip of plastic just above the drive.
Lift the lower case off.
For more information, check out the PowerBook G4 Titanium Onyx
device page .
Fantastic! Great work!
Your profile has been updated to show that you completed Installing PowerBook G4 Titanium Onyx Lower Case. Change your mind? Oops, I actually didn't do it.
Did you successfully follow this guide? I did it! Success!
This guide has been completed 0 times.
