first image
Add Note Edit Step 37  ¶
  • Lift up the metal brackets on either side of the upper case.
first image
Add Note Edit Step 38  ¶
  • Disconnect the inverter cable and carefully thread it through the slot in the upper case.
  • Carefully thread the display and backlight cables individually through the slot in the upper case. Be very careful with the display cable as it is easily damaged.
  • Remove the display assembly.
first image
Add Note Edit Step 39 — Inverter Board  ¶
  • Lift the inverter board out of the computer.
Next » « Previous
For more information, check out the PowerBook G4 Titanium Onyx device page.
Did you successfully follow this guide?
This guide has been completed 1 time.
