Installing PowerBook G4 Titanium Mercury PMU
Author:
iRobot Difficulty: Moderate
The Power Management Unit, hidden beneath the DVD drive.
Embed this guide With the HTML code below, you can embed this guide as a small widget on your website.
Files Tools Relevant parts
Edit Step 4
RAM
Release the tabs on each side of the RAM chip at the same time. These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
Pull the RAM chip out.
Repeat this process if a second RAM chip is installed.
Edit Step 5
Lower Case
Using your thumbs, slide the lower case away from you.
The lower case may stick in the front on a tab just above the center of the DVD drive. Be careful as you work the case off, or you may break the thin strip of plastic just above the drive.
Lift the lower case off.
Edit Step 8
Hard Drive
Remove the hard drive by gently grasping the orange ribbon cable and lifting the left edge up and out of the computer.
There are four rubber bumpers that fit over the hard drive screws. Ensure that these bumpers come out when you remove the hard drive.
Edit Step 12
DVD Drive
Before continuing, place a soft cloth on your work surface to rest the computer on. Turn the G4 over, making sure the DVD drive doesn't fall out.
Carefully peel the adhesive strip away from the DVD drive. The plastic dust shield covering the DVD drive is easily damaged. Try to start at the four corners and work toward the center.
Bend the silver metal EMI clip so that it is vertical. This part may fall out after removing the DVD drive.
The EMI clip is not essential for reassembling the computer. If the clip falls out, don't worry about putting it back in.
Remove the DVD drive by lifting the right edge up and out of the computer.
If you have a CD or any other object jammed in your optical drive, we have an optical drive repair guide .
Edit Step 16
PMU
Turn the G4 over.
Peel the orange tape away from the three connectors on the PMU board. Leave this tape in place so you can reuse it when reassembling the G4.
Disconnect the two orange cables and one multicolored cable from the PMU.
For more information, check out the PowerBook G4 Titanium Mercury
device page .
Fantastic! Great work!
Your profile has been updated to show that you completed Installing PowerBook G4 Titanium Mercury PMU. Change your mind? Oops, I actually didn't do it.
Did you successfully follow this guide? I did it! Success!
This guide has been completed 4 times.
