Installing PowerBook G4 Titanium Mercury Modem
  • Author: iRobot
  • Difficulty: Moderate
  • Add Note x
56k internal modem, standard on all models.
Sections
Files
first image
Add Note Edit Step 1 — Keyboard  ¶
  • Remove the battery.
  • Turn the keyboard locking screw so that it is parallel to the space bar.
  • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
first image
Add Note Edit Step 2  ¶
  • Rest the keyboard face down on the trackpad area.
  • Disconnect the keyboard connector from the logic board.
first image
Add Note Edit Step 3  ¶
  • Your laptop should look approximately like this.
first image
Add Note Edit Step 4 — RAM  ¶
  • Release the tabs on each side of the RAM chip at the same time. These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
  • Pull the RAM chip out.
  • Repeat this process if a second RAM chip is installed.
first image
Add Note Edit Step 5 — Lower Case  ¶
  • Turn the G4 over.
  • Remove the eight Phillips screws from the lower case.
first image
Add Note Edit Step 6  ¶
  • Using your thumbs, slide the lower case away from you.
  • The lower case may stick in the front on a tab just above the center of the DVD drive. Be careful as you work the case off, or you may break the thin strip of plastic just above the drive.
  • Lift the lower case off.
first image
Add Note Edit Step 7  ¶
first image
Add Note Edit Step 8 — Hard Drive  ¶
  • Disconnect the hard drive ribbon from the logic board using a spudger or the tip of your finger.
first image
Add Note Edit Step 9  ¶
  • To free the hard drive, remove the two T8 Torx screws from the right wall of the battery housing.
first image
Add Note Edit Step 10  ¶
  • Remove the hard drive by gently grasping the orange ribbon cable and lifting the left edge up and out of the computer.
  • There are four rubber bumpers that fit over the hard drive screws. Ensure that these bumpers come out when you remove the hard drive.
first image
Add Note Edit Step 11  ¶
first image
Add Note Edit Step 12 — DVD Drive  ¶
  • Before continuing, place a soft cloth on your work surface to rest the computer on. Turn the G4 over, making sure the DVD drive doesn't fall out.
  • Carefully peel the adhesive strip away from the DVD drive. The plastic dust shield covering the DVD drive is easily damaged. Try to start at the four corners and work toward the center.
first image
Add Note Edit Step 13  ¶
  • Bend the silver metal EMI clip so that it is vertical. This part may fall out after removing the DVD drive.
  • The EMI clip is not essential for reassembling the computer. If the clip falls out, don't worry about putting it back in.
first image
Add Note Edit Step 14  ¶
  • Turn the G4 over.
  • Disconnect both orange ribbon cables from the logic board using a spudger or the tip of your finger.
first image
Add Note Edit Step 15  ¶
  • Remove the DVD drive by lifting the right edge up and out of the computer.
  • If you have a CD or any other object jammed in your optical drive, we have an optical drive repair guide.
first image
Add Note Edit Step 16 — Modem  ¶
  • Turn the G4 over.
  • Using a 5 mm nut driver or needle-nose pliers, remove the hex nut from the modem.
first image
Add Note Edit Step 17  ¶
  • Lift the modem out by pulling up and to the right.
  • The plastic shielding on the modem may catch on the computer's case. Rocking the modem from side to side will help free the modem.
first image
Add Note Edit Step 18  ¶
  • Disconnect the connector cable from the modem.
For more information, check out the PowerBook G4 Titanium Mercury device page.
Did you successfully follow this guide?
This guide has been completed 0 times.
Required Tools
Phillips #0 Screwdriver
$4.95 · 50+ in stock
T8 Torx Security Bit Screwdriver
$6.95 · 50+ in stock
5mm Nut Driver
$9.95 · 11 in stock
Related Products
Recommended Tools
Home Tech Toolkit
$24.95 · 22 in stock
Sorting Tray
$7.95 · 16 in stock
Anti-Static Wrist Strap
$7.95 · 50+ in stock
Pro Tech Base Toolkit
$59.95 · 50+ in stock
Thirsty Bag
$9.95 · 50+ in stock
