Installing PowerBook G4 Titanium Mercury Hard Drive
Prerequisite Only
Prerequisite Only
This guide is only used as a prerequisite for other guides and is not a complete or useful guide when viewed independently.
  • Author: iRobot
  • Difficulty: Easy
  • Add Note x
  • x 6
How to remove the hard drive, along with its cable and bracket from your computer.
first image
Add Note Edit Step 1 — Lower Case  ¶
  • Turn the G4 over.
  • Remove the eight Phillips screws from the lower case.
first image
Add Note Edit Step 2  ¶
  • Using your thumbs, slide the lower case away from you.
  • The lower case may stick in the front on a tab just above the center of the DVD drive. Be careful as you work the case off, or you may break the thin strip of plastic just above the drive.
  • Lift the lower case off.
first image
Add Note Edit Step 3  ¶
  • Your laptop should look approximately like this.
first image
Add Note Edit Step 4 — Hard Drive  ¶
  • Disconnect the hard drive ribbon from the logic board using a spudger or the tip of your finger.
first image
Add Note Edit Step 5  ¶
  • To free the hard drive, remove the two T8 Torx screws from the right wall of the battery housing.
first image
Add Note Edit Step 6  ¶
  • Remove the hard drive by gently grasping the orange ribbon cable and lifting the left edge up and out of the computer.
  • There are four rubber bumpers that fit over the hard drive screws. Ensure that these bumpers come out when you remove the hard drive.
first image
Add Note Edit Step 7  ¶
For more information, check out the PowerBook G4 Titanium Mercury device page.
Did you successfully follow this guide?
This guide has been completed 6 times.
Required Tools
Phillips #0 Screwdriver
$4.95 · 50+ in stock
T8 Torx Security Bit Screwdriver
$6.95 · 50+ in stock
Recommended Tools
Home Tech Toolkit
$24.95 · 22 in stock
Sorting Tray
$7.95 · 16 in stock
Anti-Static Wrist Strap
$7.95 · 50+ in stock
Pro Tech Base Toolkit
$59.95 · 50+ in stock
Thirsty Bag
$9.95 · 50+ in stock
Popular Device Products
Universal Drive Adapter
$29.95 · 28 in stock
G4 Titanium Mercury Speakers
$29.95 · 9 in stock
Airport Card
$49.95 · 1 in stock
